60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Library Components, Metric and Imperial
Sun, Sep 19, 2010 at 2:25:52 PM | Library Components, Metric and Imperial
dev41113
Hi All,I have RAC2010, and have loaded the Metric library, if I need to load Imperial library , how do  I do it?
b) Can we have both the librarys loaded together and if so how do we do it? and are there any implications such as slowing of the system due to it.
Your suggestion would be appreciated, thanx in advance
Fri, Sep 24, 2010 at 12:13:03 AM | Library Components, Metric and Imperial
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes you can, but why??
if you are using metric in your office (country) than you don't need the Imperial library, it's the same content just with imperial units...
there is no extra load on Revit, you can add as many libraries as you want, it's only a path in Revit to where your library sits.
Integrator
KarelCAD
Sat, Feb 5, 2011 at 11:16:00 AM | Library Components, Metric and Imperial
nasrgolden2
hi everybody
do you know if i setup the Material Library is that mean that i have metric & Imperial components or no?
how could i load these in to my revit?
Mon, Apr 30, 2012 at 12:38:59 PM | Library Components, Metric and Imperial
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Yes you can load more than one library.
In windows do the following:
Control Panel -->  Add Remove Programs  -->  Select Revit  --> Uninstall/Change
When you do this it will give you 3 options: Add of Remove Features, Repair or Reinstall, or Uninstall.
Select Add or Remove Features and you can add more libraries.
I for one like to use both, as I do projects in both metric & imperial countries, and the default library is not the one I use most.
www.globaldesignstudio.com
Be Inspired!
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Imperial metric question RAC2009
Fri, Jan 9, 2009 at 11:35:51 AM
Nwe user: Using Revit in Imperial and Metric units
Sat, Sep 29, 2007 at 9:57:47 PM
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial to Metric
Fri, Aug 8, 2008 at 4:11:17 PM
Page generation time: 0.4485
