119 Users Online (117 Members):
Forums >> Revit Building >> Technical Support >> Project Templates
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
After you have created a project with schedules, all the "transfer project standards" related stuff, sheets, etc, you can "saveas a template". All good, except that saves all the building model info, details, etc. Is there a way to do this without having to manually delete all of the drawing information and just have the "blank canvas" similar to the revit pre-loaded templates?
You only have a couple of options: - Start a new template and transfer ...copy / paste what you need to create it or:
- Delete the model content from what you have.
I would do #2 - fairly easy. - Just go to a 3D view - make sure all model elements are on, window and delete.
- Goto a plan and delete all column lines
- Goto an elevation and delete all but two levels... your choice
- Using your shift key, pull down through you views in your browser high-lighting what you don't want and delete from the browser. (Leave the plans associated with the levels you kept). Leave the NSEW Elevations
- Do the same for the sheet views.... I would leave some and clean up your title sheet.
- Goto your room schedule and delete all the rooms that are left.
- Go through your legends and discard what you don't want.
Transfer Project Standards - View Templates |
Mon, Aug 29, 2011 at 12:03:03 PM
Managing Family Templates |
Fri, Apr 29, 2016 at 3:40:54 PM
Revit Structure Project Templates |
Wed, Apr 18, 2012 at 5:29:56 PM
Templates |
Wed, Oct 3, 2007 at 10:50:13 AM
Templates by Unit? |
Thu, Jan 12, 2017 at 1:39:47 PM
Members: | 2017329 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
