72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Cannot detach from central !!! plz help !!!
Fri, Sep 17, 2010 at 3:29:29 AM | Cannot detach from central !!! plz help !!!
cundall
Every time i go to detach the model from the central file and save it, it some how reverts itself back to a central file. Ive took myself off from all the worksets and made sure that ive relinqished myself before i go to detach but it still wont work !!!!what im i doing wrong, can anyone help with this annoying problem ?????
Fri, Sep 17, 2010 at 7:11:12 AM | Cannot detach from central !!! plz help !!!
When you open a file in Revit - even detached, you still have to use the save - as function and check the "make this file a central" box..... and you need to give it a different name.
Fri, Sep 17, 2010 at 7:22:35 AM | Cannot detach from central !!! plz help !!!
cundall
so is there a way of making a model with worksets activated into a standalone file by detaching it ?
Fri, Sep 17, 2010 at 8:17:45 AM | Cannot detach from central !!! plz help !!!
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Once you make a file workshared, it will alway be workshared.
Fri, Sep 17, 2010 at 8:29:55 AM | JAMESHGRIMES
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting JAMESHGRIMES from 2010-09-17 08:17:44
"Once you make a file workshared, it will alway be workshared."
and "alway" means always
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
detach from central file
Wed, May 12, 2010 at 12:28:24 PM
Detaching from Central Model...I CANT!
Fri, Aug 27, 2010 at 10:26:56 AM
Detach from central - Linked files
Fri, Dec 16, 2011 at 12:50:04 PM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:54 PM
Plug-ins?
Fri, May 8, 2015 at 8:03:36 AM
Page generation time: 0.4368
