97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> Tags in Legends not possible....workaround?
86 Posts No Rating |
Since it is not possible to tag in legend sheets, i'd like to know if there are any good workarounds for this? I want to use legends to create in example a sheet for an overview of all my used windows. In this sheet I would like to add information like width,heigth,type,material etc. This kinf of information could be easy to get with a tag...but that's not possible. Any other ways? Thanks!
You can use material tags in legends and you can dimension window and door legends. For our windows - especially curtain wall windows, we use an elevation (hidden in plans). We turn off everything in the elevation except the window. Now we can use tags and whatever else we need.
![Bimman Avatar](user_avatar/938.jpg)
![1 Stars: 2 Votes](/images/stars_1.gif) |
we do our window elevations the same way Hubb described.
----------------------------------- PWD |
Ok, tried this. The only thing is that you can't put the windows in a nice order? If you move a window it is logically moved in the entire project. How do you do this? We're used to windowsheets with everything in a nice order, aligned etc....
you can place the elevation view any where you want on the sheet. in any order.
Elevation Tags |
Wed, Jun 21, 2006 at 9:13:57 PM
Door and Window Tags in Legends |
Tue, Jan 22, 2008 at 2:57:19 PM
Window Schedule en Legends related to window MARKS |
Tue, Sep 8, 2009 at 8:00:50 AM
Legends |
Sat, Nov 24, 2007 at 12:14:00 PM
Window & Door Legends |
Thu, Sep 10, 2015 at 12:41:54 AM
Members: | 2022385 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
