64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Align painted surface
Thu, Sep 16, 2010 at 5:01:56 AM | Align painted surface
HuibersJarring
Sorry for my bad english, but i'm from holland.
When creating some walls, some area's won't show the surface pattern.
when i paint those walls the pattern can't be aligned.
Is there a way to fix this ?
Thu, Sep 16, 2010 at 5:17:22 AM | Align painted surface
4 Stars: 203 Votes
You can't align because you are using "Drafting" and not "Model" patterns, use the model, then you can align, move, rotate that pattern.
Thu, Sep 16, 2010 at 7:16:35 AM | Align painted surface
HuibersJarring
I am using an model pattern, and the pattern can be aligned at walls and roofs.
But sometimes the edges of walls haven't got an pattern so i paint them with the same pattern.
But once this is placed it can't be aligned.
Look at the picture to see that the walls are aligned, but the edge of the wall is not.
Thu, Sep 16, 2010 at 7:18:22 AM | Align painted surface
HuibersJarring
i'm sorry, here is the example
Thu, Sep 16, 2010 at 7:23:48 AM | Align painted surface
I'm not sure that I have run across that but instead of painting the surface, why not set up the exterior face to return at ends of walls.
Thu, Sep 16, 2010 at 7:47:28 AM | Align painted surface
HuibersJarring
Sometimes the answer is so simple... Thanks !
Fri, Jul 22, 2016 at 1:28:23 PM | Align painted surface
ernestoernesto
Hi,
I ran into the same issue recenlty and was able to fix this by simply using the "Align Tool" in an elevation. Hope this helps!
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:34 AM
19
painted split face doesn't show in dependent view
Mon, Nov 1, 2010 at 12:32:14 PM
Painted surface
Thu, Aug 30, 2007 at 12:31:02 PM
Floor pattern showing through objects
Tue, Apr 1, 2014 at 7:52:44 AM
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:21 AM
Page generation time: 1.3118
