89 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> filter ceiling tag heights
79 Posts No Rating |
Is it possible to filter out a particular ceiling tag when it equals a certain height? I'm working in a large project and we have noted that all ceilings shall be 9' unless noted otherwise. Therefore, we'd like to delete out all of our 9' ceiling tags that were created with a tag all not tagged command. Thanks for any help..
13 Posts No Rating |
Hunterfloyd: You can create a schedule to view all ceiling heights based on the room number. Just like a door schedule. This will allow you to find all of the rooms and their heights in the project. Unfortunately, you cannot select the instances here and then delete. I believe you need to delete these manually. Remember that Revit usese schedules really well. Use them for maintence and for production. Cheers, Revit Cafe
----------------------------------- Please visit me at Revit Cafe www.revitcafe.com |
Depends on how many rooms are 9'-0". It might be easier to delete all ceiling tags by using select all instances. Then come back and manually tag the ones that aren't 9'-0".
I'm kinda typing as I think here, so this may not be as good a solution as I'm thinking. Erase all your tags. Create a schedule that will group your ceilings by height (not sure if this is possible, but it seems like it should be). Select the schedule row with the ceilings you want tagged, then alt+tab back to the view you want the tags to be in. You should now have only the ceilings you want tagged selected. Now when you do a tag all, you should have the option to tag only the selected elements.
Tagging multpile ceiling heights in the same plan |
Tue, Jan 8, 2008 at 4:46:30 PM
Ceiling heights in schedules |
Thu, May 26, 2005 at 9:26:42 PM
ceiling tag for mass created clg. |
Mon, Jun 2, 2008 at 12:38:04 PM
Ceiling Tag associate to Center of Ceiling instead of Perimeter. |
Mon, Feb 8, 2016 at 12:46:31 PM
Apartment Groups - Ceiling heights |
Mon, Jul 21, 2014 at 11:11:51 AM
Members: | 2057605 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
