Forums >> Revit Building >> Technical Support >> Trouble building Parametric window - Someone wanna take a look?
So I'm going to make a Parametric Window with all different kind of setups, I haven't gotten very far but I've come to a problem. Please download the file and take a look. I'm trying to make the Windowframe changeable, and if you try to mark it and change in "component" it works fine. But I would like to be able to do this in a project too! Thats why, if you press Properties, I've tried to add under construction a drop-down list where i can choose between the two frames. Although, when changing between them in the properties, nothing happens, and that is my problem. Can anyone notice what I've done wrong? I'm quite a newbie and I've just learned adding more advanced properties than measurements. Kindest regards
Hey, you window looks fine, but incomplete. I dont know if this is what you need, but here it goes anyway -The "window" you want to use on the opening was a nested family. You must use a shared parameter to edit that parameters, since it was a simple extrusion its better to do it in the family itself. -I add that same extrusion, check where i use the "lock" feature (the padlock)so its dependent to the width/height that its already on the family, and inside the extrusion where i add the "Smygdjup","Karmdjup", or any of that ( i dont knw that language) so you can model what you really need. -You need to make that extrusions on "exterior" or interior views, so its hosted on a front/back reference plane.
13 Posts No Rating |
bengtm: This is nesting families. Nest both families and make them visible based on the parameter under element properties.
----------------------------------- Please visit me at Revit Cafe www.revitcafe.com |
Ah, I think I solved it now by setting "Karmtyp" (frametype) under Label in the Properties bar.
Parametric sweep profile? |
Mon, Jul 17, 2006 at 8:32:13 AM
Parametric Building Constraints |
Tue, May 1, 2012 at 9:43:01 AM
Parametric window |
Thu, Dec 13, 2018 at 12:27:16 PM
Parametric Aluminium Awning Window Anyone??? |
Tue, Nov 3, 2009 at 2:13:38 PM
Editing window family |
Mon, Jul 27, 2009 at 3:34:14 PM
Members: | 2115386 | Objects: | 23192 | Forum Posts: | 152305 | Job Listings: | 3 |
