49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Rendering light trouble...
Tue, Sep 14, 2010 at 11:39:20 PM | Rendering light trouble...
pappster
I am new to Revit and to rendering...why not learn it all at once!
The lighting in the images is difficult to control I cannot get my "swinger a' pendants on or a typical recessed can light. I have check that they are in the right light group and that group is on. Any ideas?
Your help is greatly appreciated!
Tue, Sep 14, 2010 at 11:41:44 PM | Rendering light trouble...
pappster
FYI...this is Revit 2011 and only the Swinger A lamp is shown in the attached image...it is the yellow one over the desk.
Thanks-
SP
Wed, Sep 15, 2010 at 3:03:42 AM | Rendering light trouble...
4 Stars: 203 Votes
You must edit that family and check if there is something wrong.
Are you render "Interior: Artificial only"?
Wed, Sep 15, 2010 at 9:43:19 AM | Rendering light trouble...
pappster
Yes, it is interior-artificial only. What might be wrong with the family? I don't even know what to look for there...
Wed, Sep 15, 2010 at 10:11:22 AM | Rendering light trouble...
4 Stars: 203 Votes
you must check if you have any object created in frot of the light souce, if so, what is the material you have? Glass? is that light a Spot? Omni? Wattage? Lumens?
Wed, Sep 15, 2010 at 5:02:14 PM | Rendering light trouble...
pappster
  • spherical light source
  • emit from point
  • 100 watts
  • luminous flux 14854.20
  • 10' distance
  • fabric material but not at bottom where light should shine thru
Wed, Sep 15, 2010 at 10:30:32 PM | Rendering light trouble...
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Simple, just change "emit from point" to "emit from circle"......
Thu, Sep 16, 2010 at 9:33:25 AM | Rendering light trouble...
pappster
Thank you so very much! It worked!
Generic Model turned Light Fixture not rendering
Thu, Aug 2, 2012 at 9:58:00 AM
Rendering - light blub missing
Fri, Nov 4, 2011 at 1:08:09 PM
Rendering And Light Settings Revit 2009 [ 1 2 ]
Tue, Oct 20, 2009 at 3:06:24 AM
26
Rendering issues
Mon, May 16, 2011 at 10:18:23 PM
Rendering light sources within a custom curtain wall panel
Mon, Sep 26, 2011 at 2:59:10 PM
Page generation time: 0.5753
