57 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Transparent object
Tue, Sep 14, 2010 at 11:34:25 AM | Transparent object
johnnyutah54
I know how to make an object transparent in a view by overriding graphics => Elements/Categories => Transparent.
Is there a way to globally set an object or a catagory to be transparent? Otherwise, if I have an object in 50 views that I want to be transparent, I will have to go through all 50 views and override...
Thanks!
Tue, Sep 14, 2010 at 12:12:06 PM | Transparent object
You are talking about a view setting.  As such, it is only controlled through views.  For categories, you can set this using view templates.  For individual elements, you have to use the over-ride.
Tue, Sep 14, 2010 at 12:22:36 PM | Transparent object
johnnyutah54
Thanks for the response. You are correct about the view template, however, that global change to make something transparent (or halftone for that matter) only works for overall categories, not sub-categories. Since the object I have created is a wall, but with its own sub-category, I can not change it to transparent that way, unless I want all walls to be transparent.
Tue, Sep 14, 2010 at 1:16:31 PM | Transparent object
TKennedy
4 Stars: 7 Votes
Set up a filter.
Tue, Sep 14, 2010 at 1:18:35 PM | Transparent object
smriti1234
can sum1 plz aathch a building in rvt format in dere plzz...it shld hav some 3 4 levels...
it need not be a detailed one...i just need to add dem in a complex..so jus de interior would do gr8..!!
plzz attch it ...or if u hav some link from where i can download it plz temme....plz reply ..!!
Imported object transparent faces
Tue, Mar 15, 2011 at 2:44:53 PM
Transparent rendering
Fri, Jun 6, 2014 at 7:15:58 AM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:07 AM
elevations have gone transparent
Wed, Jun 6, 2012 at 6:02:05 PM
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:35 PM
Page generation time: 1.6202
