78 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> open dome with vertical and horizontal metal bands
2 Posts No Rating |
Hello everyone, I am now learning revit architecture 2011 and am having some difficulty on how to go by drawing this open dome. the dome has vertical 4'X12" and horizontal 8"X2" aluminum bands. please see attached images. Thank you for your help it is much appreciated. Respectfully, frankjas08
In the Metric or Imperial Library there should be a number of base Mass shapes. One of which is a dome. Load and place it on the appropriate level, then using the massing tools place a curtain system by face, swap the panels to empty system panel if you don't require them and place mullions on the grids as required.
Regards,
Chris.
2 Posts No Rating |
Thank you Mr. spot, I will draw it up per you directions.
Rendering Images for vertical metal wall panels and standing seam roof? |
Wed, Apr 19, 2006 at 9:13:39 AM
Framing along a vertical curve |
Thu, Jun 21, 2012 at 1:01:00 PM
Metal Panels for Pre-Engineered buildings |
Thu, Dec 16, 2004 at 12:58:45 PM
Vertical and horizontal bracing connections |
Mon, Jun 24, 2013 at 7:18:38 AM
How to do a vertical reveal in a sweep in a curved wall? |
Thu, Oct 22, 2009 at 2:04:26 PM
Members: | 2022438 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
