Forums >> Revit Building >> Technical Support >> Place height of roof-based elements
86 Posts No Rating |
Hello, what is the best way to be able to control the place height of roof-based elements in a roof? For example: place a velux M-04 in your roof, and you want the top of the velux is located 2400mm above a certain level. Doesn't work with ref-planes.... Any ideas? Thanks
"Doesn't work with ref-planes...." What do you mean. Refplanes in a project or family. Need more info.
In a project. If you create something as a "roof-based-family", how can you give it some parameter or something, to determine the height to a level once placed in a project...?
I usually build this functionality into the family by creating associations with a "movable" ref plane in a family.
Yes, that was my first thougt. Only the problem is, that in a roof-based family there is no floor, or level...so nothing to align or dimension to?
0 Posts No Rating |
BUMP.
Can anyone answer this? I am looking to create a height parameter for these, but with roof based families you cannot?
When loaded into the project, some families can't also be moved up and down within elevation. This is a MUST for us to be able to set PV panels and skylights at specifc heights.
Edited on: Mon, May 21, 2018 at 5:08:54 AM
The problem obviously is, how does elevation work with a sloping roof? The unit has to move in the x-y as well as z direction.
If yo set a refernce plane in an elevation view, you can probably pick an interscetion of your unit with the roof and slide it up/down the roof to an intersection of the roof and that plane.
Can't place face-based family on roof in Plan view (but can in 3-D?) |
Tue, Oct 8, 2013 at 2:02:59 PM
How to maintain wall height when using Roof by Footprint and extending roof... |
Thu, May 18, 2017 at 4:50:12 AM
Roof curb always vertical? |
Thu, Sep 6, 2012 at 10:24:28 AM
Actual Window Head height |
Thu, Jun 7, 2007 at 5:44:30 PM
populating roofs with constructive elements |
Tue, Apr 11, 2006 at 10:08:55 AM
Members: | 2114977 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
