Forums >> Revit Building >> Technical Support >> Electrical symbol + 3d drawing
86 Posts No Rating |
Hello, I'm trying to create a family for electrical symbols. I like to place a symbol on my floor (approx. 150mm above the floor, so you see it in any floor plan). In the same family I have drawn a 3d object representing a switch for example. Now I'd like to be able to give the 3d drawing a height, but the 2d symbol needs to remain on the ground. (and maybe have a text, showing the height of the switch) I've used a nested 2d symbol in a 3d wall-based family. Problem: when I give the switch a height, the 2d-symbol also moves. How can I lock the symbol to a specified height? Thanks!
Edited on: Sun, Sep 12, 2010 at 1:39:07 PM
Add a ref plane in your family, and tie the 3D stuff to that. Then add a parameter to control the ref plane.
Yes, done that. Only problem is, that the 2D symbol also moves along, can't seem to lock that...?
Edited on: Mon, Sep 13, 2010 at 3:32:04 PM
Electrical symbol tags |
Thu, May 3, 2007 at 11:58:06 AM
Symbol Electrical Schedule - How to? |
Tue, Apr 30, 2019 at 5:10:52 AM
Parametric Electrical Symbol |
Wed, Jun 16, 2010 at 6:21:47 PM
Mechanical Equipment with Electrical connections showing 0V |
Mon, Oct 11, 2010 at 8:13:43 PM
electrical symbol families |
Fri, Jun 5, 2020 at 3:57:35 AM
Members: | 2118377 | Objects: | 23198 | Forum Posts: | 152298 | Job Listings: | 3 |
