45 Users Online (43 Members):
Forums >> Community >> Newbies >> porch stairs
5 Posts No Rating |
What is the best way to add stairs to a porch or patio?
Using the Revit stairs. You don't need a level at the bottom if you are concerned about that... Just set your top and bottom of your stairs off your floor level.
Edited on: Thu, Sep 9, 2010 at 3:28:12 PM
Stair starts with riser, and ends with riser and no landing. I usually make the landing or porch a floor.
5 Posts No Rating |
Thanks, what I initially did was make the stairs but since It was all on the 1st level the stairs where just floating, so i added a ground level and that worked. Was it a more simple way to do that, without adding the level.
No - you didn't need a level at the bottom - Just a negative offset from your floor. The top of the stairs might be a negative offset off the floor to if your porch is a step down from the main floor. I would not have a level for the porch either if it is lower than the floor. Just have that floor system offset below the main level.
Vynil Porch Post |
Fri, Nov 18, 2011 at 8:05:07 AM
screened in porch |
Fri, Dec 23, 2005 at 12:21:38 PM
Front Porch Overhang |
Sat, Feb 27, 2016 at 11:08:02 AM
Downloaded the Porch of this site, how to insert? |
Fri, Nov 30, 2007 at 10:56:57 AM
trying to build custom trim treatment for porch/entry area |
Sat, Sep 3, 2016 at 10:26:37 PM
Members: | 2056516 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
