61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ramps in Revit
Thu, Sep 9, 2010 at 10:20:45 AM | Ramps in Revit
vhugomg
I know this is a common topic on revit and maybe it´s all been seen about this subjet.
My issue is that I have a parking building with some ramps that I allready made with the ramp tool... When I started my floor plan I realized that you cannot tag an spot slope on a made-with-ramp-object (I don't know why it´s not possible even on revit 2011, I think that every object on revit should be able to be tagged... whislist!) and I decided to change my ramps to curved and sloped floors.
Now I just cannot adjust the ramp with floors, my levels are fine but the way the floor is working is wrong. I´m uploading two images to explain the way is working and I hope that is only a check mark on a property and not the imposibility of revit to make floors on ramps.
Tnks!
Thu, Sep 9, 2010 at 10:31:01 AM | Ramps in Revit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Use the Modify Sub elements tools ?
Have a look at this Parkade video.
Thu, Sep 9, 2010 at 11:00:58 AM | Ramps in Revit
vhugomg
Thanks. I just did It with subelements, but the ramp-made-with-floor should be more automated, because the curvature has not a constant slope thanks to the external ratio and the internal. But it will work just fine for know.  Thanks a lot.
Thu, Feb 24, 2011 at 1:17:18 AM | Ramps in Revit
arcnap
Hi,
 do u know how to create walls on top or bottom of curved ramps - multi sloped floors? Thanks...
NAP
Thu, Mar 17, 2011 at 1:07:32 PM | Ramps in Revit
vhugomg
I think that the tool that might work for you is using atach top/base button.
Your wall is not well done because it just goes plane instead of going down with the ramp's slope. Select the wall and the revit menu will change (revit 2011) and in modify/wall menu you will see the atach top/base button, go there and select on the green bar bellow top buttons select the opcion top or base and then select the floor or roof you will use to atach your wall.
If you atach base but you dont have a roof to atach you have 3 choices:
1) Select the wall and choose modify profile.
2) Copy your ramp and paste it on the finish top level of the wall and atach the wall and turn of the element or make it thin enough so it wont bother your model.
3) Also you can make a mass extrusion with path.
Hope my anwer will help you.
Revit City I owe you so much!!! haha
Sun, Oct 13, 2013 at 8:56:57 AM | Ramps in Revit
ArchStudentWIT
3 Stars: 2 Votes
Try this link out:
http://www.youtube.com/watch?v=5GaIarzxYPQ&feature=youtu.be
Attach Walls to Ramps
Fri, Feb 18, 2011 at 6:45:17 AM
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:54 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:37 AM
Ramps unaffected by cutplane setting?
Wed, Oct 8, 2008 at 10:39:57 AM
Revit 2013 - visualization issues with ramps
Wed, Jan 16, 2013 at 2:28:03 PM
Page generation time: 2.4625
