99 Users Online (96 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit Internal Parameters..?
Thu, Sep 9, 2010 at 9:02:18 AM | Revit Internal Parameters..?
mercat11
Does anyone have or know where there is a list of Revits internal parameters? - for 2011 or earlier.
there are lots i know.
Tue, Sep 14, 2010 at 12:42:40 AM | Revit Internal Parameters..?
HuFlungDung
HuFlungDung Avatar
2.5 Stars: 8 Votes
mercat11-
it's not convenient getting stuff out of the
revit database- but autodesk usually has
a good idea what anyone might want out
of there- and gives it to you.. try this link
and see if in that model content guide at
the botton isn't what you need..
http://seek.autodesk.com/revit.htm
Tue, Sep 14, 2010 at 12:46:53 AM | Revit Internal Parameters..?
HuFlungDung
HuFlungDung Avatar
2.5 Stars: 8 Votes
mercat11-
it isn't easy getting into the revit database-
but autodesk has a good idea what anyone
might want out of there and gives it them..
see if what's in this model content guide at
the botton of the page isn't what you are
looking for..
Tue, Sep 14, 2010 at 1:04:15 AM | Revit Internal Parameters..?
HuFlungDung
HuFlungDung Avatar
2.5 Stars: 8 Votes
WOW!!
this alternate connection i'm using took so long
to establish that first post that i didn't think it posted
at all..
i need my high speed connection back..
com'on fellas- get some love in your hearts-
we're all in this together you know..
Tue, Sep 14, 2010 at 5:32:25 AM | Revit Internal Parameters..?
mercat11
ok - thanks.
As a more specific part of this question: Does anyone know if there is a parameter which would access / report the Keynote Text? keynote of course reports the actual alphanumeric value - but is the associated text available to a parameter?
Tue, Sep 14, 2010 at 8:18:11 AM | Revit Internal Parameters..?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Yes, you will need to modify the tag to "look" for the text value instead of the number value.
Tue, Sep 14, 2010 at 9:13:17 AM | Revit Internal Parameters..?
mercat11
thanks james - any idea what the parameter that i should be looking for is called?
Tue, Sep 14, 2010 at 9:39:31 AM | Revit Internal Parameters..?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Open the keynote tag family. Click on the lable and edit. Select "Keynote Text" and click the Add button. Then remove "Key Value" from the lable. Save and Reload into your project.
Tue, Sep 14, 2010 at 9:52:38 AM | Revit Internal Parameters..?
mercat11
Thanks. Although I completely forgot to mention I was trying to get the parameter to report into a schedule. There doesnt seem to be a way to do this, even though its logical it  should be available.
Tue, Sep 14, 2010 at 10:26:08 AM | Revit Internal Parameters..?
TKennedy
4 Stars: 8 Votes
Sounds like you might be looking for a keynote legend.
Tue, Sep 14, 2010 at 10:51:15 AM | Revit Internal Parameters..?
#11
mercat11
it would be the next best thing - but in this situation a schedule is required for displaying the rest of the info. Im guessing it cant be done. I was hoping it would be a case of jsut adding the parameter but it seems the parameter isnt available to schedules..
thanks anyway.
Internal Point, Line and Area Loads...Internal???
Fri, Dec 14, 2012 at 4:59:06 AM
Internal Elevation Markers
Mon, Oct 25, 2010 at 4:32:30 PM
internal lights
Tue, Feb 1, 2005 at 1:23:56 AM
Internal Origin NOT At 0,0,0 ?
Tue, Sep 1, 2020 at 7:25:21 AM
Render Internal Lighting Issue
Sun, Nov 7, 2010 at 8:04:47 PM
Page generation time: 1.7535
