139 Users Online (138 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall Sweep Grips
Tue, Sep 7, 2010 at 3:16:41 PM | Wall Sweep Grips
aneglia
I'm modifying profiles for some wall sweeps, and I notice that for some of the sweeps, the grips (the little, filled-in circle you see when you're lengthening or shortening your sweep in elevation view) is about 1"-2" below the actual sweep.  This means that when I tell the sweep (in the properties "Offset From Level" area) that I want it to be 3' from ground level, it moves the sweep so that the grip is at 3'.  Is there any way to tell Revit at what point on the sweep I want to be the basepoint?  I'd like it to be at the top of each profile, so that if I put in 5' for the "Offset From Level" value, the top of the sweep will be 5' from the floor level in elevation.
 Thanks in advance.
Tue, Sep 7, 2010 at 3:22:32 PM | Wall Sweep Grips
I believe the grip point is the insertion point for the profile.  This is set in the profile family.
Tue, Sep 7, 2010 at 3:32:13 PM | Wall Sweep Grips
aneglia
I figured it had to do with the creation of the initial profile.  So how do you set this point when you're creating your profile?
Thanks
Tue, Sep 7, 2010 at 3:58:25 PM | Wall Sweep Grips
The answer is self evident.  Starty a new profile family using the hosted template.
Tue, Sep 7, 2010 at 4:30:39 PM | Wall Sweep Grips
aneglia
Thanks for the info.
I found the template file you mentioned and put my trim profile into it.  I find is that even though I've placed the top of the profile at the "Insertion Point" (see attachment "Profiles"Winking, when I got to insert the profile into a wall sweep and insert it into an elevation, it chooses the bottom of the profile as the insertion point instead (see "Profiles1"Winking.  What am I doing wrong?
Wed, Sep 8, 2010 at 12:28:26 PM | Wall Sweep Grips
I haven't had an opportunity to look at this.  It may be that what you have observed is how Revit does it.
Sat, Sep 11, 2010 at 5:13:54 PM | Wall Sweep Grips
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Aneglia, the grip for your sweep is ALWAYS going to be at the intersction of the X and Y ref planes in the profile family.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Mon, Sep 13, 2010 at 4:49:28 PM | Wall Sweep Grips
aneglia
Thanks for the response.  If the intersection of the X and Y planes is always the grip, or insertion point, then why doesn't my profile work this way (see my attachments in my previous reply).  I've placed the top of my wall sweep profile right at the intersection, but as you can see from accompanying elevation drawing, the grip is show to be at the bottom of the profile instead of the top.  Boggles my mind.
Wall Layer Grips Missing
Wed, Dec 2, 2015 at 8:37:53 PM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:18 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:45 PM
19
Wall sweeps VS Generic Models
Sat, May 21, 2011 at 10:14:20 PM
How to Load a Wall sweep type
Mon, Jun 9, 2008 at 12:42:30 PM
Page generation time: 1.0328
