50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> exporting material library to another revit model?
Mon, Sep 6, 2010 at 6:57:00 PM | exporting material library to another revit model?
tommytucker
hey all,
i need to export one material library from one revit model to another, how can i do this in revit 2011?
thanks in advance,
tom
Tue, Sep 7, 2010 at 5:38:40 AM | exporting material library to another revit model?
4 Stars: 203 Votes
Did you try to open the two projects, then select a simple component with that material (a wall for example), then CTRL-C, go to the new project and CTRL-V, it's a simple copy/paste, also, in Manage tab you have "Transfer Project" where you can transfer what you want from one project to the other, in this case select only "Materials".
Mon, Apr 7, 2014 at 11:29:01 AM | exporting material library to another revit model?
gabbiano85
may I export a material library of revit 2013 in order to open the same material library in revit 2014?
thanks
Mon, Apr 7, 2014 at 12:13:16 PM | exporting material library to another revit model?
Txabarri
In the Manage tab, go to transfer project standards and select MATERIAL. Im not sure you can do it in the 2011 version but I think so.
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:17 AM
Question about shared custom material library
Wed, May 18, 2016 at 6:44:31 AM
Material library
Fri, Mar 3, 2006 at 9:11:37 AM
Exporting Revit 9.1 Model to 3ds Max, Material Issues
Tue, Oct 16, 2007 at 10:38:26 AM
Help me! Lack of BMCD2AR3 material library in revit building 8.
Sat, Oct 8, 2005 at 9:54:16 PM
Page generation time: 2.9885
