Forums >> Revit Building >> Technical Support >> Stair Surface Pattern Not Displaying
103 Posts No Rating |
In Revit 2011, I assigned a tile pattern to a set of stairs I created Type Properties/Tread Material & Riser Material). The pattern shows up in the model just fine, but fails to display in the plan, even with the detail level set to high. I know that the pattern settings should be correct since the nearby floor slab in the drawing is displaying the same pattern properly. Is there any way to fix this stair surface pattern problem?
Check Visibility and Graphics to see if the surface patterns for stairs has been turned off. Also check to see if there are any element overrides applied to the stair.
Thanks for the suggestion, but I'm not seeing Surface Patterns in the list of Graphic Overrides under stairs. All I see is Down Arrow, Down Text, Hidden Lines, Stairs Beyond Cut, Stringers, Stringers Beyond Cut, Up Arrow, & Up Text. I wonder if there is another category besides stairs that I'm not seeing.
I have never seen a surface pattern show on plan views of stairs - only 3D views.
Edited on: Wed, Sep 8, 2010 at 9:51:26 AM
That's what I'm finding out too. I fail to see the logic in this decision by the programmers. One more thing to add to the list for the next round.
I see what you mean. The lines for stairs in plan is a symbolic representation, just like symbolic lines in families.
Unable to rotate/align surface pattern on stairs |
Thu, Aug 28, 2014 at 7:29:21 AM
Extruded roof - surface pattern displaying incorrect |
Wed, Sep 8, 2010 at 10:00:12 AM
Stair Tread Surface Pattern |
Tue, Feb 8, 2011 at 1:56:43 PM
How do you rotate surface pattern on stair treads and landings? |
Fri, Oct 23, 2015 at 4:22:41 PM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:02 AM
Members: | 2101759 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
