51 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Print entire projekt to single pdf files
1 Posts No Rating |
Hello all revit users.. I have now been reading on this forum for a while and what a great place. So many really good topics, great community. But now I am having a problem, have done some search without any luck. Here we go: I want to print multiple sheets at different paper sizes at once and I need them as single pdf files. So each floor plan to a pdf on it´s own and so on. This would save me tons of time, now I have to print each sheet individual. I know I can export to a dwf and keep different paper sizes, after that I can print to pdf. BUT I need single pdf files. I am thinking maybe I could export each sheet to dwf in a fast way ? And then print them to pdf´s ? Or is this possible in any other way, all ideas are very welcome… Thanks in advance. And again great forum J - Spock
13 Posts No Rating |
When I want to do this I use a PDF program called PDX Xchange 4.0 as my pdf printer. I then print all the pages that are the same size to a file. Then do the next size and append to the existing PDF file. If they are in the wrong order or orientation I can use the PDF viewer to correct this. Other PDF writers may be able to do the same thing.
Print to PDF sheets with DWG files on them help. Maybe Bluebeam help |
Mon, Oct 26, 2015 at 10:55:35 AM
print to single pdf |
Tue, Feb 13, 2007 at 8:03:59 AM
Combine multiple sheets into a single PDF file per THE SHEET INDEX |
Fri, Jul 31, 2015 at 3:00:27 PM
converting files |
Wed, Aug 24, 2016 at 9:55:18 AM
Print Order |
Wed, Nov 21, 2012 at 2:17:41 PM
Members: | 2022237 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
