55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Saving
Fri, Sep 3, 2010 at 9:21:58 AM | Saving
tsg870
Anyone know why I can only Save as a Template and not as a File??? What's the difference?
Fri, Sep 3, 2010 at 10:04:18 AM | Saving
4 Stars: 203 Votes
Because you are saving in RTE and not in RVT, check this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=3448
Fri, Sep 3, 2010 at 10:06:20 AM | Saving
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Because you opened a template file.
If you want to use a template for a project, you need to tell Revit to open it as a project. If you open a template, you can only save as a tempate file and you lose some application abilities like worksharing.
Search the help for Creating a Project Using a Template
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Sep 3, 2010 at 12:51:50 PM | Saving
tsg870
Thanks.
 So if I have an .rte file, I can't save it as .rvt?? Do I have to start over?
Fri, Sep 3, 2010 at 1:00:33 PM | Saving
brettgoodchild
4 Stars: 17 Votes
No,
Save everything you have done so far as an rte file. Then, under the applications menu pick on New > Project.
Then, just browse to the rte file you just saved and then tell it to open as a project.
See the attached image
                             ~ Abraham Lincoln
Fri, Sep 3, 2010 at 1:07:48 PM | Saving
tsg870
Ohh, got it. Thank you, thank you!
local file saving location [ 1 2 3 ]
Thu, Jul 10, 2008 at 8:03:09 AM
38
saving in previous releases
Wed, Oct 11, 2006 at 3:44:32 PM
Saving to Central
Thu, Mar 12, 2009 at 9:42:05 PM
Saving detail
Mon, Jan 8, 2007 at 10:47:10 AM
Saving New Textures
Thu, Dec 1, 2005 at 6:39:32 PM
Page generation time: 0.1959
