54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> revit 2009 error message
1 Posts No Rating |
Hi I'm a high school teacher my students are using Revit Arch. 2009. Things were going along find and now the students are receiving an error message when they try to save their work. Message something like an unexpected error has occured and revit must close. We are working through the SDC book Residential Design using Revit Arch. 2009. Any help will great we are at a stand still.
Can you tell us a little about the machines you are using? Most times, this error message is a memory issue. Has the 3 gigabyte switch been set on these machines? You can read about that process on the AutoDESK site.
You might try downloading the Update 3 pack from Autodesk. There may be a fix in there
3D window error message-Revit 2009 |
Fri, Sep 15, 2017 at 2:51:33 AM
error message prevents upgrade to revit 2009** |
Wed, Jul 23, 2008 at 9:04:28 AM
Revit 2014 - Disappearing error message |
Wed, Nov 6, 2013 at 4:12:48 PM
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
Keep getting Error message - Can't make type... |
Fri, Mar 26, 2010 at 10:35:10 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
