98 Users Online (97 Members):
Forums >> Revit Structure >> Technical Support >> timber and steel to have different detail levels
Hello. I have a building drawn on revit. some of the floors are timber joists, others are concrete supported on steel beams. My question is that on my g.a. I want the steel beams to display as 'coarse' and the timber joists to display as 'meduim' or 'fine'. Unfortunately i don't seem to be able to find a way of doing this. any help would be much appreciated. David Bowles
No, you can split up the overall view settings by objects but you can set up a view template to show categories differently. Through VG, you can control line style , line weight, transparency, color, cut patters and sub category elements. Obviously, you don't want to have to do this manually, so do it by template.
Applying a timber surface to a sloped steel roof? |
Thu, Aug 14, 2008 at 11:22:43 AM
Colorbond wall_section structure...HELP!! |
Thu, Aug 2, 2007 at 9:22:01 PM
How to make a curved timber batten wall? |
Tue, Jun 7, 2011 at 5:49:49 AM
Timber Framing |
Tue, May 9, 2006 at 9:04:39 AM
Chamfered edge timber plinth |
Mon, Jun 27, 2011 at 9:52:33 AM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
