53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Possible for an object to rotate a material?
Thu, Sep 2, 2010 at 7:33:56 AM | Possible for an object to rotate a material?
JeroentjeM
Hello,
We're building houses with bricks. I use render materials for this. Sometimes there is something we call a "rollaag" (don't know what's it called in English...) that means a row of bricks vertically, instead of horizontally. To create these "rollaag", I use wall sweeps, with a profile the size of a brick.
Is there a way that this sweep takes the material from the wall, but 90° rotated? Cause if I have to do it manually, each time a customer changes brick color, I have to create new materials by hand, for the "rollaag".
Any ideas? Thanks!
Thu, Sep 2, 2010 at 7:41:52 AM | Possible for an object to rotate a material?
3.5 Stars: 396 Votes
There is no way to do what you want but just assign the material to the sweep.  If you give that sweep material a name like "rollage", you can just change the material assignment to rollage in the project and it will change everywhere.
Thu, Sep 2, 2010 at 8:22:46 AM | Possible for an object to rotate a material?
JeroentjeM
Hey WW, thanks for the thinking. This is the way i'm doing it now. Only disadvantage is you have to create a new vertical material, for each horizontal material you change. But okay, we can't exclude all mouseclicks can we? Smile
Is there a way that the material hatch (surface pattern) aligns with the render material? So if I use the surface pattern to align windows, the render looks good too? Or is this just tweakin with the used patterns?
Thanks!
Rotate of family
Wed, Feb 24, 2010 at 1:32:32 AM
how to know the material used in a specific object?
Mon, May 9, 2011 at 1:14:23 PM
rotate material on fascia
Mon, Nov 23, 2015 at 10:29:03 AM
3d Rotate object
Tue, Nov 18, 2008 at 5:08:34 PM
EDITING FAMILIES-NEED TO BE ABLE TO FLIP THE OBJECT PLACED 4 WAYS
Thu, Aug 19, 2010 at 6:10:01 AM
Page generation time: 0.5010
