120 Users Online (119 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> CAD Linework over Toposurface
Wed, Sep 1, 2010 at 12:34:18 PM | CAD Linework over Toposurface
spohler
Is there a good way to get imported CAD linework (set at z=0) to overlay on the toposurface? Either it is partially buried in the land or it is sitting high above, floating in the air. I would like it to follow the contours so that it is all visible at once and not floating.
I am working in 2011.
Thanks!
Wed, Sep 1, 2010 at 12:38:50 PM | CAD Linework over Toposurface
The CAD linework is 2D.... it is on a plane above, below or wherever you place the dwg.  It is 2D so there is no way for it to drape over your surface.
Wed, Sep 1, 2010 at 12:46:53 PM | CAD Linework over Toposurface
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Not sure if this helps but you can do a graphics override in the view and make the toposurface 'transparent'.
That way you CAD linework won't get barried or hidden by the topo ? Worth trying I suppose.
linked CAD linework
Tue, Oct 22, 2013 at 3:46:11 PM
Toposurface problem
Thu, Feb 25, 2010 at 4:37:33 PM
toposurface
Tue, Dec 6, 2005 at 3:49:57 PM
Can you save linework?
Tue, Aug 12, 2008 at 7:37:07 PM
Within Revit Linework
Mon, Jun 23, 2008 at 4:16:05 PM
Page generation time: 1.9844
