86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> why linked revit file is invisible in my building.rvt only show property line
Wed, Sep 1, 2010 at 9:58:12 AM | why linked revit file is invisible in my building.rvt only show property line
zazem
Hi,
I am using revit architecture 2011.
and
I want to link a site plan file (toposurface + building pad) to my building file.
after i linked them up, using "Link Revit",
it shows "the import geometry will not be visible in the view using the current setting".
 but when i tested to link my site plan file to another building file ( downloaded from somebody's blog),
it works fine.
Why?
Wed, Sep 1, 2010 at 10:01:23 AM | why linked revit file is invisible in my building.rvt only show property line
3.5 Stars: 395 Votes
You mean linking a Revit site model?
If so, is the site at a lower elevation than the view range that you are in?
Check your VG settings for your view.  Tpography & Site
Wed, Sep 1, 2010 at 11:05:29 AM | why linked revit file is invisible in my building.rvt only show property line
zazem
thanks for reply,
 I try to link a site plan to building plan.
 I try the view range and moved to building and site plan in same level
still doesn't show up
still only can see  property line, and highlight boundary of linked file when you move mouse over it.
 any cure? or can you explain more details?
thx in advance
Wed, Sep 1, 2010 at 11:17:00 AM | why linked revit file is invisible in my building.rvt only show property line
See previous post .....VG
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
Linked File line weights
Thu, Feb 2, 2012 at 1:08:00 PM
DWG visibility in linked files
Mon, Nov 10, 2014 at 9:00:17 PM
Linked rvt into another rvt
Tue, Jan 20, 2009 at 12:21:13 PM
Rotating property line and site without moving building...
Sat, Jun 15, 2013 at 10:31:20 AM
Page generation time: 4.5418
