63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curved Roof with tapered edges?
Wed, Sep 1, 2010 at 2:00:01 AM | Curved Roof with tapered edges?
egoled
Dear AllI have a curved roof, which I have made using roof by profile but I need to cut back the rrof as an overhang on the extruded edge of the roof as per the attachments.
I have tried making a mass and cutting the geometry but this does not seem to work, I am reluctant to make the roof as a mass as I will need to make sections and sooner or later 1:5 details.
I hope someone can advise on the easiect way forward?
many thanks
egoled
Wed, Sep 1, 2010 at 4:28:15 AM | Curved Roof with tapered edges?
4 Stars: 203 Votes
If i understand this issue and i think you create that roof by "Extrusion" what you need to "Cut" just use an "IN-PLACE" family in the "ROOF" category, then create a "Void extrusion" in a elevation view and use the "Cut Geometry" tool between the void and the roof, now you can finish the in-place family, also, you can create a "Mass" with the shape you want then in "Massing and site" use the "Roof by Face", if you need to change anything in that roof, edit the Mass, change the mass like you want, finish the mass, select the roof and in the options bar you have a button "Update to Face", this will update your roof to the new shape of the mass.
I hope this help.
Cheers
Edited on: Wed, Sep 1, 2010 at 1:22:47 PM
Openings on a curved roof
Sat, Jul 25, 2009 at 2:35:49 AM
sloped curved roof
Sun, Mar 22, 2009 at 7:28:03 AM
Roof Slope and Tapered Insulation [ 1 2 ]
Sat, Jul 28, 2012 at 8:08:29 AM
19
CURVED MASSING FOR ROOF BY FACE
Tue, Jul 20, 2010 at 5:24:24 AM
Sloped and curved roof
Mon, Jan 2, 2012 at 10:07:28 AM
Page generation time: 0.7385
