42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> change curtain by pattern system material
3 Posts No Rating |
I would like to change the material of a curtain by pattern system I created using a mass, when I access the instance properties I only get 3 options: clear, glazed or solid. I would like to place a translucent white plastic material, but I can’t find a way, I’ve also tried with the painting option but it doesn’t work either. How could I do it?Thanks
Select the Panel (use the TAB key if you need), go to properties, duplicate (give another name), change what you need like material and thickness.
3 Posts No Rating |
Same thing, the is only 3 options available
Same answer.
3 Posts No Rating |
I got it now, thanks a lot! :D oh and excuse my english, is not my native tongue.
Curtain system > glazing panel matherial |
Mon, May 28, 2012 at 1:02:14 PM
Curtain Wall Window Material |
Wed, Dec 15, 2021 at 2:04:35 PM
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
Standing Seam Metal Roof Material |
Tue, May 19, 2009 at 9:58:48 AM
Curtain system from mass - Revit 2014 |
Fri, Jun 17, 2016 at 12:20:49 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
