76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> hidden lines in structural
13 Posts No Rating |
easy one this I guess
I'm trialing the Structural release & must say v impressed
Now one thing is driving me mad
If I have a panel of RC beams & slabs, the only way I can get the hidden view of the structure is to move the slabs up (or beams down) a fraction - not ideal - and I suspect its me, not the software.
1 Posts No Rating |
Hey,
Try looking under the View Range setting in the View property dialog box and changing the cut plane.
JB
thankyou JB
I have had a play around and see the possibilities in the VP dialogue now
I have yet to see a pattern though that gives me consistant reliable results
All slabs are 225 thk, all RC beams are 600 deep - to create a simple outline with beams & column head heads dotted I though my settings should be Top Offset 10, Cut Plane 10 (ie above the slab so their is no cut linestyle for the beam, Bottom offset -600) - I'll keeep trying though & thanks for your help
SS
Still no luck
So I've attached a file with 2 very simple arrangements in it - plus some text to explain my difficulties
any help would be much appreciated - I'm sure it's a me thing!
SS
8 Posts No Rating |
Hi,
Try using the linework command type "LW" and select the lines to change to hidden etc, you can adjust the length of the line with its grips.
Regards
Anthony
antfa
Thank you very much - that's just the job! - i knew it would be easy & how simple it turned out to be
SS
8 Posts No Rating |
no worries,
I struggled with the same problem a few days ago
Cheers
Antfa
Show Hidden Lines - Structural Foundations |
Thu, Jan 13, 2011 at 10:37:01 AM
how do you make structural beam systems visible. |
Fri, May 8, 2009 at 4:34:31 AM
Show hidden lines |
Wed, Apr 16, 2008 at 5:52:55 PM
Structural link showing colored lines - please help! |
Thu, Dec 2, 2010 at 3:32:36 PM
Show Hidden Lines Tool and Detail Elements |
Fri, Nov 22, 2013 at 8:48:50 AM
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
