134 Users Online (133 Members):
Forums >> Revit Systems >> Technical Support >> i had gotten this error message
4 Posts No Rating |
"The routing solution failed because there is no default fitting type specified or the fitting cannot be found in the project. Ensure the fitting is loaded in the project and try again." this never happened and now is. any ideas how to fix this? thanks.
I assume you're using MEP. Can you isolate where the phantom fitting is located in the project? Or the name of the family?
4 Posts No Rating |
no i cant. i also get there error message " no auto-route found" i think these 2 messages are connected in some way but im not sure.
I use MEP 2011. If you select your Pipe (or duct) and then click on Edit Type in your properties dialog box, what fitting types are displayed for that pipe (or duct)
Gary |
See this post. http://www.revitcity.com/forums.php?action=viewthread&thread_id=7963
Edited on: Mon, Aug 30, 2010 at 5:18:12 PM
4 Posts No Rating |
Im using 2011 mep as well. i took a look and although the pipe type says copper its showing pvc standard and pvc sched 40 dwv fittings.
Did the previous post with the link help out?
Gary |
4 Posts No Rating |
not sure. it started working right again on its own but thank you for your help it is appreciated.
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
Revit 2014 - Disappearing error message |
Wed, Nov 6, 2013 at 4:12:48 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016 |
Tue, Oct 4, 2016 at 9:09:33 AM
Keynotes Error Message |
Mon, Jan 24, 2011 at 9:12:17 AM
Error Message |
Fri, Feb 18, 2011 at 2:24:25 PM
Members: | 2057355 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
