50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Reverted to demo version after fixing error problem 2011
Mon, Aug 30, 2010 at 10:27:59 AM | Reverted to demo version after fixing error problem 2011
JsBach
 I have been learning Revit using the Autodesk assistance program. I recently started getting an unrecoverable error message at the startup screen. After researching I found the common solution to this fix was to delete the WSCCommCntrData and UIState files as directed. However, once I did this I am stuck in demo mode so can't save anything. How do I get back the student version?
Mon, Aug 30, 2010 at 11:03:52 AM | Reverted to demo version after fixing error problem 2011
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Hmmm, don't know about WSCCommCntrData but I believe deleting the UIState file(s) just resets the ribbon and quick access toolbar back to the original installed configuration.
A re-install is probably worth a try.
The 'student version' of autodesk products have their own behaviour. Maybe contact the people you got the software from?
In Canada there are only two Educational Resellers and the US probably have 3-4.
Mon, Aug 30, 2010 at 11:29:51 AM | Reverted to demo version after fixing error problem 2011
coreed
coreed Avatar
4 Stars: 16 Votes
did you try re-resgistering the software?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Sep 4, 2010 at 11:13:15 AM | Reverted to demo version after fixing error problem 2011
JsBach
I was able to fix this finally. The first thing I had done before deleting the files listed was to reinstall the program. After I deleted the files was when I posted this. So after deleting the files and then reinstalling, the program works again.
 As a warning, I also tried reinstalling the older 2010 version and just as it was finishing, I got a blue screen crash and was not able to start up my computer except in safe mode. Luckily I had a restore point that worked, I had done a couple of restores when trying to figure out why Revit wasn't working. This wasn't a one time deal either, I tried installing the 2010 version again and another blue screen crash. Very scary, Autodesk should look into what in their download program is causing a system crash.
Sat, Sep 4, 2010 at 5:36:04 PM | Reverted to demo version after fixing error problem 2011
BCMArch
BCMArch Avatar
JsBach-
here's a little secret- (big secret actually)- and never have that
kind of problem again..
1. get windows 7 if you don't already have it.. because window 7
will nearly automatically reinstall itself..
2. get the utility program for your system C: hard drive- and zero fill that drive..
3. pop in the win 7 disk- type in the product code- come back in 15 minutes..
4. install revit..
5. be the happiest revit user at revit city..
Sat, Sep 4, 2010 at 6:42:24 PM | Reverted to demo version after fixing error problem 2011
BCMArch
BCMArch Avatar
JsBach-
hopfully you don't say- like many revit users say:
"oh i can't do that no matter how easy or how
perfect it solves my problems because i would
lose all my work and all my projects"
just get out of the bad habit of saving your
work to your C: drive and into the good
habit of saving your work to an external
drive.. and always back-up that first
external drive to a second external drive
in case one of them fail..
imagine there's no crashes
it isn't hard to do
nothing to waste time for
and no blue screens too
Error message installig off-line revit 8.0 demo version
Sat, Jul 2, 2005 at 10:26:00 PM
Revit/Globe Link 2011 "Aquiring"
Thu, May 19, 2011 at 1:20:05 PM
Error when inserting views from a Revit file (version 2011).
Mon, Nov 29, 2010 at 1:22:24 PM
Lost Work (model has reverted back)
Thu, May 1, 2014 at 2:38:26 PM
Copying tags from an older version of a project.
Mon, Jan 18, 2010 at 1:17:47 PM
Page generation time: 2.3963
