86 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Revit TotD - 8.30.2010 | Controlling your Demolition In-Fill Types
Mon, Aug 30, 2010 at 8:47:58 AM | Revit TotD - 8.30.2010 | Controlling your Demolition In-Fill Types
rkitect
rkitect Avatar
4 Stars: 29 Votes
An easy quick tip to start off the day.  Phasing can be a pain to even the most seasoned Revit veterans, and hopefully I can help you out with a little in-fill issue you may have in the future.  When you demolish a door, window or any wall cutting object out of a wall, it replaces that former opening with an in-fill wall.  This wall has no phase information but can be replaced with ANY wall type you have already defined.  If you have a scenario where you want to replace the in-fill area with a different wall type (say you have a CMU/Concrete building and just want to in-fill with stud walls), this tip is going to be right up your alley!
  1. Demolish your wall cutting object
  2. In your next phase view, select the in-fill create by the previous demolition.
  3. Choose the wall type you wish to use.
  4. Choose the location line alignment.
  5. Voila!  Quick, easy and painless!
As always, you can view this tip in its entirety at  http://revittotd.com/08/1029.  Thanks for stopping by and please feel free to leave feedback!
-Carl Gibson
Edited on: Mon, Aug 30, 2010 at 9:05:28 AM
Revit TotD – 6.30.09: Room Tag Types “I don’t have that option!”
Tue, Jun 30, 2009 at 5:14:23 PM
Revit TotD - 8.26.2010 | Quick Plan Perspectives (via View Cube context menu)
Thu, May 31, 2012 at 3:02:54 PM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM
Revit TotD – 7.30.09: Revit 2010 Add-In Manager
Thu, Jul 30, 2009 at 7:08:14 AM
Revit TotD – 2.24.10 | Render Texture Alignment
Wed, Feb 24, 2010 at 9:10:30 AM
Page generation time: 1.8790
