51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> ELLIPTICAL STAIR
3 Posts No Rating |
CAN YOU ANYONE SHOW HOW TO MODEL ELLIPTICAL STAIRS? MUCH APPRECIATED FOR THE HELP.
An elliptical stair can be drawn the same as a straight stair using the line tools under the stair construction tab. NOTE: You will have to use simple arcs to create your ellipse. I know this is an approximation of an ellipse but I really prefer this because you can dimension this and then the contractor can actually build this. A true ellipse is very hard to build in the field and I don't think anyone can really see the difference.
Edited on: Sun, Aug 29, 2010 at 10:10:53 AM
7 Posts No Rating |
I am using 2012 and there is still no Elliptical option for creating Stairs!? I am trying to model Elliptical Residential Stairs to be built on a CNC machine. I need the stairs to be exact.
Are People using Inventor, or 3DS max to model stairs for this stuff? or is there a way to do this in Revit that I am not seeing?
Please help
"Wherever you go, there you are" |
![coreed Avatar](user_avatar/14568.jpg)
i would suggest that you try the Conceptual Mass modeller. but you will have to totally model your stair. which i would assume would be the same with Inventor, 3d Max etc. But you know what they say about assuming.
Elliptical sloped roof in Revit |
Thu, Jan 23, 2014 at 6:01:52 PM
Elliptical concrete columns |
Tue, Aug 15, 2006 at 5:46:28 AM
Elliptical stairs help |
Thu, Sep 1, 2011 at 10:15:49 PM
14
Stairs and Railings Of Course |
Fri, May 24, 2013 at 9:41:23 AM
Parametric elliptical shape in family |
Fri, Feb 20, 2015 at 4:30:19 AM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
