92 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curved Curtain Wall
Thu, Aug 26, 2010 at 9:27:27 PM | Curved Curtain Wall
skip9
5 Stars: 2 Votes
Hey guys, just wondering if any body could help me out with curving a curtain wall from top to bottom - i have tried creating a mass and then changing the face to a curtain wall but it would let me create it. I Can create the profile as a wall and then extrude it but not as a curtain wall.Here is an image of what im similarly after.It is the front curtain wall of the image.
Fri, Aug 27, 2010 at 8:32:49 AM | Curved Curtain Wall
4 Stars: 203 Votes
You can create a "Mass" with that shape, then in "Massing and Site" just use the "Curtain System", select the face you want and click on "create" in the Top menu... Also, you can create an "IN-PLACE" family in Home>Component>Model in place, select the category you want then create a "Solid Extrusion" with that shape.
Sun, Aug 29, 2010 at 3:16:03 AM | Curved Curtain Wall
skip9
5 Stars: 2 Votes
Typhoon, the only problem with this is that when i create the curtain system from selecting the face of a mass, it creates a curtain wall that is essentially 3 different angles rather than an arc?
Sun, Aug 29, 2010 at 6:11:23 AM | Curved Curtain Wall
4 Stars: 203 Votes
Exactly, or you edit that curtain system and change/divide in more parts OR if you want a perfect arc/curve you need to create that in a "IN-PLACE" like i told you before.
curved angled curtain walling
Wed, Mar 8, 2006 at 4:18:50 AM
curved curtain wall, straight transoms, curved panels
Tue, May 12, 2015 at 8:36:03 PM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
curved curtain wall
Sun, May 12, 2013 at 1:54:01 PM
curtain walls
Sun, Dec 7, 2014 at 9:29:54 PM
Page generation time: 11.5722
