50 Users Online (49 Members):
Forums >> Revit Structure >> Technical Support >> Detaching from Central Model...I CANT!
140 Posts No Rating |
I am trying to detach a model from centralto give the model to our Architect...or to experiment in the project. But even when I hit the "detach from central" radial box, then save...and reopen...still referencing the central model. I cannot get the model to detach. Help..
Once a project has been set to workshared it will always be workshared. The solution is to do as you have done but set the save to save as new central file. This will still be a workshared file but it can reside as a seperate central.
It must be fate...I am working on a Razorback building. Thanks for the reply
Detaching file from central and working individually |
Mon, Jun 4, 2012 at 12:08:49 PM
Central Model rolls back to previous version |
Thu, Jun 5, 2014 at 7:47:21 AM
can't view file properties - central path |
Fri, Aug 21, 2009 at 2:34:53 PM
updating a revit arch model error (REVIT 12) |
Fri, Mar 1, 2013 at 4:06:42 PM
Converting Central Model to Basic Model |
Wed, Jul 2, 2014 at 11:48:21 AM
Members: | 2030850 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
