74 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Default stair railing
Thu, Aug 26, 2010 at 5:19:28 AM | Default stair railing
archie456
3 Stars: 1 Votes
Hi,
When I draw a stair in Revit 2011, it appears with a railing each side.
Where is the type of this default railing set? I cannot see any settings in the stair type properties dialog box.
Cheers.
Thu, Aug 26, 2010 at 6:00:11 AM | Default stair railing
4 Stars: 202 Votes
"When I draw a stair in Revit 2011, it appears with a railing each side." - By default when you create a stair appear those railings unless when you are in sketch mode of that stairs on top/right menu you will see the Railings where you can select None or select a couple of more but you can duplicate one of them and change the properties and use it like you want, after you created your stairs, you can select the railing, go to properties and change it if you want/need.
In project browser expand the "Families" you will see "Railings", "balusters" ....
Edited on: Thu, Aug 26, 2010 at 6:07:10 AM
Thu, Aug 26, 2010 at 1:08:27 PM | Default stair railing
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Also something to keep in mind.
'Default railing' is actually dynamic. It is simply the LAST railing you created by using the 'railing' tool all by itself.
So to change the 'default' railing just start the railing tool, create a railing on it's own with the type you want, then delete the railing and now you have set that railing to the 'default' railing. Weird but true.
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:40 PM
Railings and Stairs
Fri, May 16, 2014 at 12:12:17 PM
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:34 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:23 PM
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:40 PM
Page generation time: 0.3608
