86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Count
Fri, Oct 14, 2005 at 12:34:02 AM | Count
cadjockey
Hi all, How do I exclude a door or window from being counted within a schedule? cadjockey
Fri, Oct 14, 2005 at 12:53:58 AM | RE: Count
Scott Davis
3.5 Stars: 3 Votes
Make a new Yes/no parameter in the window familiy called "IsScheduled". When loaded, you can check this on and off. In your schedule, use the filter to display only those windows that are checked "IsScheduled"
Fri, Oct 14, 2005 at 3:50:27 AM | RE: Count
cadjockey
Thanks Scott.
Mon, Oct 17, 2005 at 12:31:49 AM | RE: Count
cadjockey
Scott, I have managed to create a new yes/no instance parameter for my windows. I loaded the unpdated famiiesy into my project. The parameter shows up and I am able to check the box for a particular window. In my schedule however, the option to filter by this paramter is not available. Is there something else I must do? cadjockey
Mon, Oct 17, 2005 at 12:41:15 AM | RE: Count
cadjockey
Hi Scott, No problem. As I have created a separate phase called doors/windows as part of the way I have set up my door schedule drawing sheet. All I need to do is set the schedule to show only new construction. This has fixed the problem. cadjockey
Schedule Count as Percent of Grand
Thu, Dec 22, 2011 at 10:33:17 AM
ROOM COUNT SCHEDULE
Tue, Aug 22, 2006 at 2:45:49 PM
Schedules - Calculated Value does not have "Count" in the list of fields
Thu, Oct 17, 2013 at 8:55:44 PM
Wall Panel Count
Tue, Apr 3, 2007 at 10:06:34 AM
Schedule Count Parameter
Wed, Sep 2, 2009 at 11:02:10 AM
Page generation time: 0.2150
