93 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> Render quality
16 Posts No Rating |
The walls in the attached rendering looks if they had mold or some kind of texture when I have applied only white paint....what caused them to look like this? I assume it's a lighting issue. How can I fix it? Cheers!
I kind of like that mold look. . . . . . . . try adding interior lighting. Looks like your already there. Also from what I can tell there is a 'bump' pattern in the out of the box Paint Material. Maybe turn that off and play with some of the other material settings shown below.
20 Posts No Rating |
Turn on "daylight portals" when you render. I had this same problem initially. Revit treats exterior light differently if it knows it is coming through windows and this will remove the "mold" issue. FYI, it will also take a lot longer to render.
thanks gentlemen. Answering to dgcad: a. it already has interior lighting; b. as far I am concern that's no "bump" pattern for paint....at least when I checked. Your attachment shows "plant" not "paint". Answering to ndarchi03: Daylight portals were on so......
Render Quality |
Thu, Apr 28, 2005 at 3:27:47 PM
render and quality of computer |
Wed, Nov 20, 2013 at 10:48:04 AM
Render problem |
Thu, May 30, 2013 at 12:37:29 AM
REVIT RENDER QUALITY SETTINGS DIALOG BOX |
Thu, Dec 18, 2008 at 11:04:04 AM
High Quality Rendering Error |
Thu, Mar 26, 2009 at 3:11:23 PM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
