71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Lettering Set up
Thu, Oct 13, 2005 at 9:35:17 PM | Lettering Set up
JAIMERIOSJR
I am fairly new using Revit. I need to find out how can I modify the font types for the Elevations, Cut symbols, schedules, etc... what part of settings should I modify? Thanks Post edited on 2005-10-13 21:35:25
Fri, Oct 14, 2005 at 3:55:15 AM | RE: Lettering Set up
fazerneil
4 Stars: 5 Votes
If you want to set up notes text for example, select text, properties, edit/new, duplicate, give it a name, click the "text font" value box within text properties and a drop down list of fonts appears. select. Change height etc to suit, "apply" and "ok" twice. You now have a diferent text. If you mean to change the text in "tags" then you need to edit the tag family and select a different text style by doing the above within the family itself.
Incised V groove lettering
Wed, Mar 30, 2022 at 3:09:46 PM
Hand lettering TTF
Wed, Feb 1, 2006 at 8:45:30 AM
Neon/ Glow in the Dark Signs/Lettering Anyone
Tue, Oct 28, 2008 at 8:16:27 AM
detail lettering or numbering
Wed, Dec 1, 2010 at 11:07:38 AM
View Template
Mon, Mar 18, 2013 at 3:15:06 PM
Page generation time: 0.7352
