33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> First beam offset in beam system
Sun, Aug 22, 2010 at 11:21:45 PM | First beam offset in beam system
satheeshbabu
There is no option to give first beam offset in beam system. Is there any work around? Anyone please help me.
Mon, Aug 23, 2010 at 8:43:57 AM | First beam offset in beam system
jterrell
3 Stars: 5 Votes
Unpin the beam and make modifications to it.
Mon, Aug 23, 2010 at 12:24:13 PM | First beam offset in beam system
hhwse
As jterrell says you can unpin it and make modifications.  If you are just moving to the edge of the first beam you can use lateral justification to side 1 or side 2 and re-pin and it will retain that information.   If you are trying to change the location of the entire system from the default locations (center, end, beginning), I do the following.1.        Place the system using end or beginning.2.        Use the measure tool to find out how far I want to move the system.3.        Use edit boundary to make the necessary modifications to the boundary.
Beam system, cant offset?
Fri, Feb 13, 2009 at 8:16:03 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
beam system
Thu, Oct 15, 2015 at 7:32:17 AM
Beam system not sitting on beam
Thu, Jan 3, 2013 at 11:40:10 AM
Page generation time: 1.6727
