74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> formula for schedules
Sun, Aug 22, 2010 at 10:38:33 AM | formula for schedules
adiga
i need to create a formula to multiply the area by cost in the material take off schedule
it tells me (inconsistent UNITS) !!!!!!
HOW CAN I DO IT ???????
Sun, Aug 22, 2010 at 10:57:33 AM | formula for schedules
Please read your HELP on units and formula.  Another thing you should always try is a search of the forums.  In this case using the term "inconsistent units" would find this post from Mr Spot:
"....Okay the confusion comes because cost is a number and area is m�. Therefore when you create a calculated value for total cost you select number... Now revit is looking for a number yet your units when for instance going cost*area is m�.... Try this cost*(Area/1) This will effectively remove the units from the value...."
Sun, Aug 29, 2010 at 8:44:57 AM | formula for schedules
adiga
thnx alot that was very usefull Smile
Thu, Mar 22, 2012 at 11:06:24 AM | formula for schedules
rramirez
Thank you ! ! ! this information is much appreciated.
Door Formula for schedules?
Fri, Aug 10, 2007 at 8:44:24 AM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Schedules - Calculated Value does not have "Count" in the list of fields
Thu, Oct 17, 2013 at 8:55:44 PM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Page generation time: 0.4114
