Forums >> Revit Building >> Technical Support >> Realistic Style Help
3 Posts No Rating |
I'm having issues trying to see my model in the realistic view style.. In fact with the exception of the wire frame view, all options look about the same to me. I thought it might be because my graphics card isn't supported (I've been getting that error message when I start up my program and ignoring it up until now) but this view style does show up properly for me when I am editing a mass.. so it seems capable of it as far as I can tell. Is this the problem? I'm guessing there is something very simple that I'm missing here, but as I am extremely new to Revit and basically self taught I'm not sure what it is. Any help would be greatly appreciated
graphics card issue. BTW, what is the model of your G.C.?
3 Posts No Rating |
Makes sense thanks for your help!
post a view of the couple of differing view options. Card may not be the problem.
3 Posts No Rating |
Turns out I simply had my floor plans and views set to mechanical under dicipline. Once I changed them to architectural everything showed up properly. But thank you both for the help!
Having problem with realistic style mode in Revit Architecture 2012 |
Wed, Jun 22, 2011 at 8:04:36 AM
Walkthrough in realistic view, not rendered |
Wed, Aug 27, 2014 at 12:00:38 PM
Realistic Trees in Site Plan |
Fri, May 6, 2016 at 3:29:32 PM
mirror showing as black in realistic visual style |
Fri, Oct 17, 2014 at 1:48:08 PM
Revit graphics, problem with Realistic and Shaded Visual style |
Wed, Nov 28, 2012 at 3:56:35 AM
Members: | 2115576 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
