101 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> Custom-made Curtain Walls
11 Posts No Rating |
I'm working on a patio room project and I need to customize curtain wall panels for use in the future. They need to have a horizontal mullion at 2' 3" and another one at 4' 6" above finish floor level. They also need to have vertical mullions at distances that can be easily changed. Does anyone know how to do this? Any help would be greatly appreciated. Also, can doors be placed in this curtain wall panel? Thanking you in advance, mgruenba
You can duplicate the curtain wall, give it another name, change in properties the grid lines spacing (hor./vert.) and the mullions like you want, then save that in your template file, in this way, every time you create a new project that curtain wall is there, about the doors, you only can place a "Curtain Wall Door" into curtain walls, just load the curtain wall door you want then select the panel in the curtain wall (use the TAB key) and change that panel for the CW-door.
custom curtain walls |
Sat, Nov 1, 2008 at 10:49:38 AM
Loading Custom Curtain Wall Panel into file |
Mon, Sep 15, 2014 at 9:19:41 AM
Loading a Custom Curtain Wall |
Mon, Mar 8, 2010 at 1:24:47 PM
Custom panel family within a curtain system |
Tue, Nov 3, 2009 at 11:59:10 AM
Inserting Custom Curtain Panels Into Angle/skewed |
Fri, Apr 30, 2010 at 4:50:44 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
