59 Users Online (58 Members):
Forums >> Revit Structure >> Technical Support >> Beam skews at an angle
2 Posts No Rating |
Hi. Newbie here. Here's my problem: I moved my slab edge out a couple of feet and I'm trying to drag the beam end to meet the edge of slab. Instead of going straight out and becoming flush with the slab edge, the beam skews at an angle. Is there anything I can do to fix this?
![1 Stars: 1 Votes](/images/stars_1.gif) |
Welcome! If I am uunderstanding you correctly, one thing you can do is place an angular dimension from the beam to the slab edge. Select the beam, and edit the angle. One thought: Try out the align tool under the Modify tab - this would have aligned the beam with the slab edge or vice versa very nicely!
2 Posts No Rating |
I tried the "align" command and it worked perfectly! Thanks!
Steel Beam - Angle |
Thu, Feb 1, 2018 at 4:02:25 AM
Angled Beam Issue |
Mon, Aug 26, 2013 at 6:09:39 AM
Drawing a Chord Angle |
Mon, May 12, 2008 at 1:00:41 PM
parametric beam |
Sun, Jul 23, 2006 at 6:46:24 PM
Spot Lighting Beam Spread |
Sun, Nov 9, 2008 at 9:20:16 AM
Members: | 2016974 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
