129 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Indicating a Furr Down
Wed, Aug 18, 2010 at 10:11:16 AM | Indicating a Furr Down
cadman7577
1 Stars: 1 Votes
Trying to find the best practice to indicate a furr down.  Old School in CAD I would have a section cut indicated at the furr down on my reflected ceiling plan.
 Any good ideas out there?
 Thanks
Sun, Aug 22, 2010 at 11:02:36 AM | Indicating a Furr Down
Whad do you mean "section cut"?  I assume your ceiling plan is cut around your cabinets.
Mon, Aug 23, 2010 at 9:48:18 AM | Indicating a Furr Down
cadman7577
1 Stars: 1 Votes
well you know you work in AutoCAD for 12yrs it's hard to get way from things.  But what I'm talking about is, I have a ceiling at 9'-0"  Then I have a furr down and the other side the ceiling moves up to 11'-0".  In cad on the ceiling plan I used to place a tag to call out that furr down detail.  I just have not found a good way to call that out.  Any suggestions would be great.
Thanks,
Mon, Aug 23, 2010 at 9:51:34 AM | Indicating a Furr Down
Why could'nt this be a "ceiling" called "Furr Down" .... Then when you tag this ceiling, it would say furr down and have an elevation....  Or just use a key note?
Tue, Aug 24, 2010 at 3:06:36 PM | Indicating a Furr Down
jterrell
3 Stars: 5 Votes
I have made an 'architectural beam' family that is really a horizontal column family. It joins to walls and shows a dashed line at the floor level. If I don't use that family, I just draw walls with an offset from the referenced floor.
Creating furr downs above cabinets...
Fri, Jul 13, 2012 at 8:36:38 AM
Furr down and ceiling joins
Wed, Mar 16, 2011 at 7:47:53 AM
Trouble getting furr down walls @ ceiling to actually be room bounding..........
Tue, Jan 26, 2010 at 11:58:11 AM
spot elevations indicating schedules symbols
Fri, Apr 23, 2010 at 4:46:17 PM
Showing voids in plan
Mon, Nov 12, 2007 at 3:13:47 PM
Page generation time: 0.9759
