61 Users Online (59 Members):
Forums >> Revit Structure >> Technical Support >> blue dots in linework
![albertiglesia Avatar](user_avatar/119685.jpg)
45 Posts No Rating |
hi, can somebody help me out from this, i always encounter this problem in which the blue dots on the linework command does not appear. we all know that this blue dots help you udjust to what extend you want the editing of certain line should be but in some cases particularly when i create section, blue dots is not shown. can somebody explain to me the theory and concept behind why this blue dots is not appearing and what is the solution for this important dots appear thanks, albertiglesia
"Pleasure in the job puts perfection in the work"
- Aristotle |
![markitekdesign Avatar](user_avatar/110469.jpg)
![4.5 Stars: 71 Votes](/images/stars_4.5.gif) |
use unhide all the object.
Linework on column woes |
Fri, Apr 29, 2005 at 12:40:35 PM
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:44 PM
Linework Tool (LW) |
Thu, Mar 11, 2010 at 4:34:30 PM
Black or Blue dots in linked Structure file |
Sun, Oct 29, 2006 at 8:00:27 PM
Remove from view structural blue dots? |
Tue, Feb 26, 2008 at 11:45:50 AM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
