Forums >> Revit Building >> Technical Support >> Coping Profile
Tue, Aug 17, 2010 at 6:46:21 PM | Coping Profile
BrianMDG
I am trying to make a sweep for a metal coping around the perimeter of the building. I have created a profile and loaded it successfully but I get a warning stating "Could not create integral wall sweep for wall instance. Sweep position is outside of its wall. Please check sweep parameters." The profile shows in the Element properties section cut but not in the wall section.  I have made modifications to the wall to move the exterior sheathing down allowing the profile to dip below the top of the wall structure.  Is this the issue?  I have check all other parameters I'm running out of ideas.
Finish Profile at Stone Coping [ 1 2 ]
Tue, Jul 29, 2008 at 1:20:47 PM
16
Problem creating coping
Fri, Aug 18, 2006 at 4:31:48 PM
Truss - coping frame members
Mon, Aug 16, 2010 at 5:51:35 AM
Parapet Wall Coping as a sweep
Tue, Feb 19, 2008 at 9:35:43 AM
profile sweep help
Mon, Sep 21, 2009 at 4:48:04 PM
Page generation time: 0.3881
