72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Topographical Datum Points
Tue, Aug 17, 2010 at 7:08:43 AM | Topographical Datum Points
egoled
Dear All
Hopefully this is a quick and easy one but i am struggling to find the answer.
I have produced a site surface using surveyors information and would like to show the datum points used as text next to the position were i placed a point.
I am aware that i can use the contour tool but I would like to use the datum levels at the points used as i will need to level out the site.
I hope someone will be able to help me.
Tue, Aug 17, 2010 at 9:40:25 AM | Topographical Datum Points
Did you try using the spot elevation tag?  Annotate / dimension tab / spot elevation
Wed, Aug 18, 2010 at 1:41:35 AM | Topographical Datum Points
egoled
I have another question.
 The surveyor has set his station point 1660mm above zero as 0 in his autocad drawing. So he has represented his spot levels as the following as an example
1680 - which in z co-ordinate is +20mm from 1660.
1590 - which is in z co-ordinate is-70mm below 1660.
So when I use the spot elevation level the reference is shown as a + and - figure. Is there a way to set the drawing so 1660 is the refernece level and the levels above and below the 1660 level are shown as the above example as 1680 and 1590.
Hopefully this makes sense. Any help will be duly appreciated.
 egoled
Wed, Aug 18, 2010 at 11:04:41 AM | Topographical Datum Points
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Carefully read your help file on topography. You can grab the surface and move it up or down to suit.
Topographical Surfaces
Thu, May 10, 2012 at 7:18:29 AM
Site/Architectural Datum
Wed, Dec 8, 2010 at 8:46:30 AM
Topographical survey
Fri, Dec 4, 2009 at 2:23:19 PM
Abolute Elevation and Topo Points - Revit Architecture 2009
Wed, Feb 10, 2010 at 12:51:32 PM
Basement Datum Level Line: Now you see it, now you don't
Fri, Nov 18, 2011 at 11:41:49 AM
Page generation time: 0.9765
