73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Strucutral Columns VS Walls in Call outs
Fri, Aug 13, 2010 at 2:43:05 PM | Strucutral Columns VS Walls in Call outs
emmettking
I am working in Revit 2011 and my walls are being cut by the structural columns in regular plan views however for my enlarged details i an using callouts of the plans.  In the call outs the structural columns are not cutting the walls.  Anyone have this problem or know the fix?
Thanks,
Sun, Aug 15, 2010 at 7:55:43 AM | Strucutral Columns VS Walls in Call outs
I have seen some similar issues like this but I can't remember the circumstances.  Are you callouts plans or details?  Try switching between them.
Mon, Aug 16, 2010 at 6:13:32 AM | Strucutral Columns VS Walls in Call outs
gprakash
Emmettking,
If you callout from plan, please also check if the material of wall and column are same. If they are/should be different , try splitting the wall to be cut for the structural column.
Edited on: Mon, Aug 16, 2010 at 6:20:25 AM
Mon, Aug 16, 2010 at 8:17:06 AM | Strucutral Columns VS Walls in Call outs
emmettking
For whatever reason the callouts are detail views instead of plan view types.  As long as the callout is made in the floor plan as a "plan" callout everyhting works fine.  No idea how someon made them into or made them as detail views.
 thanks for the help.
Call outs withing call outs
Sun, May 10, 2009 at 3:35:43 PM
Call outs in Revit
Wed, Jun 11, 2008 at 8:39:24 AM
Call Outs
Sat, Feb 27, 2010 at 5:23:34 AM
Elevation call outs missing
Thu, Apr 3, 2008 at 8:35:14 PM
Changing options on call out views so able to see on all floors
Thu, Oct 29, 2009 at 6:33:52 AM
Page generation time: 1.8784
