Forums >> Revit Building >> Technical Support >> Pin Detail elements to move with Nearby Walls etc
1 Posts No Rating |
I'm relatively new to revit. I'm using Revit Architecture 2010. My question is simple, is there a way to attach or pin detail elements like brick or insulation in a wall section to the wall, so if i move the wall they move with it? Thanks
If you mean left/right in the section, you can maybe use align and set the lock but I have not tried it.
If it's a filled region, you can lock all relevant sides. You could also use a big ugly linear dimension and lock that. Many components have temporary dimensions -- you can drag the blue dots of these temporary dimensions to relevant objects if Revit guesses wrong--and then, if you click on the |<-->| icon right near the dimension number, you can turn this "temporary" dimension into a permanent dimension. Then, once it's a permanent dimension locked to an object, you can right click on the dimension, and override graphics by view, and by element, and make it invisible!
Move detail component with nearby elements |
Thu, Oct 20, 2005 at 2:51:10 PM
How to lock walls so they move together |
Tue, Dec 21, 2010 at 12:45:46 PM
Detailed Wall and moving them. |
Fri, Oct 5, 2007 at 12:21:56 PM
Pinning all walls at once |
Thu, Feb 10, 2011 at 2:34:10 PM
pins and curtain walls... |
Fri, Aug 22, 2008 at 6:26:25 AM
Members: | 2119308 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
