77 Users Online (76 Members):
Forums >> Revit Building >> Tips & Tricks >> different height in the same wall
5 Posts No Rating |
Hi all.
I got a problem while modeling a simple garage... here it is :
I'd like the exterior layer of the wall to begin lower than the core layer.
does someone know how to do this ?
thanks
Maly Aniolek
In the wall properties you can unlock layers from aligning with each other.
Edit the wall, edit its structure.
Turn on the preview and switch it to section view.
Select the bottom edge of the layer you wish to extend. Unlock it.
Okay out of editing the wall.
Select a wall in plan and go to its properties, you notice there is now a field available for bottom extension distance.
Change this as required and there you go...
You need to go into the wall properties - Edit - Modify, Set the preview to Section, zoom in and select the bottom line of the finish layers you want to extend and unlock them. Then in the main properties dialogue box set the base extension parameter accordingly. You can also select and adjust the extension graphically in a section view. This methods applies to the top extension also.
5 Posts No Rating |
Thanks a lot for your both quick answers :-)
I have done all of the above up to the point where you unlock the edge of the layer, but i keep getting this error message when i press ok. "Cannot extend layer(s) of highlighted vertically compound wall" anyone has any idea why i cant do it? p.s : I am using RAC2008
----------------------------------- www.kaliakatsos.gr |
2015 wall height |
Fri, Jul 10, 2015 at 9:17:02 AM
Wall Openings - Changing Height |
Wed, Jan 28, 2009 at 8:05:26 AM
Wall Tag with Automatic Height |
Wed, Nov 7, 2012 at 1:57:45 PM
splitting full height wall sections |
Wed, Jul 28, 2010 at 2:13:15 PM
schedule showing wall height |
Fri, Oct 17, 2014 at 10:31:07 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
